Hard to Start. Bogs down and stalls when you hit the gas. - Toyota Tacoma Forum
post #1 of 10 (permalink) Old 09-25-2005, 09:45 PM Thread Starter
My 1998 tacoma 2wd 2.4l started rough idling today I changed out my plugs. Then it ran fine then an hour later it start shutting off at lights and then was nearly impossible to start. got it started and limped it home anything but light pressure on the throttle would cause it to bog down and shut off. I replaced the fuel filter started a little rough at first evened out. Drove it about 14 miles ran fine. Stomped on the gas and it got up and went. Shut it off turned it back on no problem. Shut it off then the problem came back. I have check the PCV valve as well it sounds fine. Any more suggestions?
Mini98Tacoma is offline
post #2 of 10 (permalink) Old 09-25-2005, 10:10 PM
trdtoy's Avatar
Re: Hard to Start. Bogs down and stalls when you hit the gas.
Maybe you have injectors trying to clog up? Try some seafoam through the system.
trdtoy is offline
post #3 of 10 (permalink) Old 09-25-2005, 10:27 PM
I could be way off but truck was doing something similar to what you're describing just last week....
I was driving along and then when I went to accelerate the truck just bogged down, anything more than barely touching the gas and it would bog and then stall.....turned out to be that my battery was dead. So perhaps you have an electrical problem (battery/alt) that's not letting the ignition system function properly.
TacomaKevin17 is offline
post #4 of 10 (permalink) Old 09-25-2005, 10:39 PM
Probation
mine did that cuz i accidently messed up my MAF. so could be that, mine did the same things as u said.
lowtoydude is offline
post #5 of 10 (permalink) Old 09-26-2005, 10:09 AM Thread Starter
I will check the battery after work today. How easy is it to get to the fuel pump or atleast check the fuel pump. Do I have to remove the bed to get to it? as far as the MAF being bad is there a way to check it before throwing down the 200$ for a new one?
post #6 of 10 (permalink) Old 09-26-2005, 01:57 PM
Chris98's Avatar
mine kind of did the same thing last week. turned out I had a loose MAF wire on the connector.
Chris98 is offline
post #7 of 10 (permalink) Old 09-27-2005, 09:18 AM Thread Starter
okay i have replaced the MAF, the fuel pump, fuel filter, removed the cat swapped plugs and wires. still not running. I am thinking its the injectors. how do i check those?
post #8 of 10 (permalink) Old 09-27-2005, 04:17 PM Thread Starter
SOULTION!!!
Its seems like my throttle body was really gummed up and blocking a few vacum lines. I cleaned it out with Carb Cleaner and it runs fine now. Knock on wood!
post #9 of 10 (permalink) Old 09-27-2005, 09:34 PM
Hey at least now you got a spare MAF and Fuel pump!
d33pt is offline
post #10 of 10 (permalink) Old 09-28-2005, 07:05 AM Thread Starter
nope I have a spare pump. But I turned the MAF in for the core. That thing was to damn expensive without the core being paid back.
