Man. Trans. Downshifting problems... - Page 3 - Toyota Tacoma Forum
post #21 of 48 (permalink) Old 01-14-2013, 07:44 PM Thread Starter
blackedout_taco_stidham's Avatar
Re: Man. Trans. Downshifting problems...
Originally Posted by tacomatic1 View Post
do you dd that truck?
But of course...an average of 2 miles per day during the week...
I like Toyotas.
blackedout_taco_stidham is offline
post #22 of 48 (permalink) Old 01-14-2013, 07:49 PM Thread Starter
Originally Posted by Enola Gaia View Post
Any chance you've bent or broken something in the shifter / linkage? Bushings? Etc.?
anything is possible i guess...
how do you remove the shifter without removing that whole access plate along with my SS? i know there is a way, but i cant remember how my dad did it on my old '87 toy...
is it believable to say that something is bent or broken and the gears still work from first through fifth shifting up, but then shifting down only fifth through third work...
I like Toyotas.
post #23 of 48 (permalink) Old 01-14-2013, 07:58 PM
671taco's Avatar
Originally Posted by blackedout_taco_stidham View Post
these are my thoughts...better just start lookin for a replacement tranny...671 what year was yours? lol
I think mine was from an 87 non-turbo supra I believe. And I daily drive my truck when I don't drive my 05 tundra!
BOOSTED 2RZ @ 434hp 368tq @ 18PSI/ OEF 10-11
671taco is offline
post #24 of 48 (permalink) Old 01-15-2013, 06:44 AM
Quoted: 198 Post(s)
... is it believable to say that something is bent or broken and the gears still work from first through fifth shifting up, but then shifting down only fifth through third work...
It's a long shot, but ...
If it turns out the tranny is OK and it's the shifter / linkage that's somehow messed up, you're gonna kick yourself when you find out you didn't have to pull the whole tranny out ...
post #25 of 48 (permalink) Old 01-16-2013, 04:07 PM Thread Starter
UPDATE!!!
found out today that if i avoid third gear all together then it shifts just fine, in and out of every gear just like normal...except third gear of course. As soon as i tried third and then downshift to second, it wasnt havin it. Can a single gear cause this kind of problem, or a single synchro...man i wish i knew more of how the inside of the tranny worked...but i guess ill learn eventually right? lol
I like Toyotas.
post #26 of 48 (permalink) Old 01-16-2013, 04:08 PM Thread Starter
i forgot about your build thread, im gunna check that out...i remember there was a bunch of useful info in it about your swap...that made me jelly, lol
I like Toyotas.
post #27 of 48 (permalink) Old 01-16-2013, 07:38 PM
Quoted: 198 Post(s)
UPDATE!!!
Soooooo ... It *does* have something to do with 3rd gear after all.
When I read your original post I thought that slam into 3rd at around 50 mph must have been the probable cause, but couldn't figure out why the subsequent symptoms all had to do with 1st and 2nd.
I still don't know what could be messed up about 3rd and cause shifting problems with 1st and 2nd.
post #28 of 48 (permalink) Old 01-16-2013, 07:41 PM
tacomatic1's Avatar
Quoted: 7 Post(s)
5th to 3rd doesn't seem like it would make the truck jerk to slow down that bad...3rd is my downshift gear, I downshift at 45-50 mph all the time and it doesn't jerk that bad.
I have however accidentally gone into 2nd trying to upshift into 4th going onto the high way around 60mph but immediately clutched in to get out of it. No issues though.
tacomatic1 is offline
post #29 of 48 (permalink) Old 01-16-2013, 07:50 PM Thread Starter
i know...it just doesn't make since...but everything def works fine if i avoid 3rd all together
I like Toyotas.
post #30 of 48 (permalink) Old 01-16-2013, 09:38 PM
Quoted: 198 Post(s)
Actually, it does seem to make sense ...
The 3rd gear is located on the output shaft immediately forward(?) of the 2nd gear, which is in turn located immediately forward(?) of the 1st gear.
Here (attached) is an illustration showing the relative locations of these 3 gears on the output shaft.
If something was broken or screwed up with the 3rd gear (or associated components), it might throw off something about the output shaft that would affect the ability to engage the other two gears on that same shaft. That would be 1st and 2nd - precisely the two gears you report having trouble with.
That's about all I can tell ... I don't claim to be a transmission expert ...
Auto trans problems toyotaman426 Performance 10 05-16-2011 05:00 AM
4x4 trans problems Fluffmagruff71 Off Road 4 09-20-2008 11:56 PM
Lowered with trans/driveshaft problems? S-rUNnKiD 1995.5-2004 9 06-21-2008 09:38 PM
So, you think you're good @ heel & toe downshifting? Rad Off Topic 20 11-27-2006 11:37 AM
problems with auto trans theELMcompany 1995.5 - 2004 1 01-08-2004 11:35 PM
