TRD rear locker - Toyota Tacoma Forum
post #1 of 11 (permalink) Old 12-30-2012, 10:48 AM Thread Starter
bskinheli's Avatar
TRD rear locker
Anyone know where to get a replacement for the TRD rear locker, besides Toyota. mine is cooked, and I just do not want to pay $1400.00 for a new one. Thanx and Happy New Year.
bskinheli is offline
post #2 of 11 (permalink) Old 12-30-2012, 05:00 PM
Yodaforce's Avatar
Re: TRD rear locker
Consider a Detroit Tru-Trac?
About a grand cheaper, and it would do everything you need it to do.
Diverse-Customs.com
Yodaforce is offline
post #3 of 11 (permalink) Old 12-30-2012, 05:24 PM
Supporting Vendor
Re: TRD rear locker
The Detroit Truetrac is a much better LSD and a lot cheaper. They also don't wear out.
You can get it from a vendor here, Just Differentials.
When you say TRD Rear Locker, are you talking about the Toyota eLocker, or the aftermarket TRD LSD made by Eaton?
G
Gadget@URD is offline
post #4 of 11 (permalink) Old 12-31-2012, 09:32 AM
Quoted: 193 Post(s)
Re: TRD rear locker
I presume he means the factory TRD e-locker. If so, he's looking for a locker and not a limited slip differential unit (LSD).
post #5 of 11 (permalink) Old 12-31-2012, 10:56 AM
HaVoCX's Avatar
Re: TRD rear locker
If your doing mainly highway/street driving, would a Limited Slip Differential (LSD) be more beneficial? how would a LSD handle in the snow?
Curious as i dont want to be ass-sideways on the snow when going skiing during winter.. AND after some researching on yotatech.com and other forums.. looks like the TrueTrac is the way to go! Im stoked as justdifferentials has em for $411
HaVoCX is offline
post #6 of 11 (permalink) Old 12-31-2012, 11:13 AM
Quoted: 193 Post(s)
Re: TRD rear locker
An LSD is usually considered the better choice for street use, because it 'negotiates' how much power is applied to each wheel (right / left rear). A locker applies the same amount of power (and rpm's) to both wheels.
A locker is better for low-speed poor traction situations, but the tail end will more easily kick sideways on you.
An LSD can be useless if one wheel loses all traction.
post #7 of 11 (permalink) Old 12-31-2012, 01:32 PM
HaVoCX's Avatar
Re: TRD rear locker
cool thx.. i did some more research of my own and find justdifferentials post really helpful. Differential and gear break in basics
HaVoCX is offline
post #8 of 11 (permalink) Old 12-31-2012, 02:57 PM
Yodaforce's Avatar
Re: TRD rear locker
Though it has it's risk (depending on the warranty given) the easiest method to replace the rear Toyota E-locker is to just find a low mileage wreck and buy the whole rear and swap it out plug and play. Atleast anyone with basic tools can do it. Setting up a gear set takes a bit more experience to get it just right.
This is usually the best time to explore other options so it's good to look around and compare.
Diverse-Customs.com
post #9 of 11 (permalink) Old 12-31-2012, 05:14 PM Thread Starter
bskinheli's Avatar
Re: TRD rear locker
Considered for sure, but would prefer to keep the TRD e-locker, more convenient, it is either in or out. Thanx for the reply.
post #10 of 11 (permalink) Old 01-01-2013, 09:49 AM
Supporting Vendor
Re: TRD rear locker
You can convert it to a LSD like the Truetrac, but it is not easy.
You do not have the normal 8.4" diff, you have the Toyota e-Locker that is the 8" diff like in the 4Runners. You will likely have to swap out the entire 3rd member to a 4Runner one that will accept the TrueTrac and you will have to make a slight modification to the axle housing. There is on stud that is in a different location and you will have to weld a cut out area closed, but you can make it work.
Might just be easier to get an entire Tacoma rear axle assembly with the 8.4" diff and install the TrueTrac into that. I am sure you can sell you current axle assembly and locking control unit to someone.
G
rear locker options for 96 2wd 2rz blazins10 Performance 23 01-14-2010 04:44 PM
OK, Peg Leg has to GO! NEED LOCKER in REAR..... boostjunkie1 Off Road 20 09-14-2008 10:30 PM
rear locker honhon 4x4/PreRunner Suspension 6 07-20-2006 05:44 PM
gears for the TRD rear end with E-locker? where to get? TRD2.4Tacoma Off Road 3 04-03-2006 03:55 PM
Rear Locker Question OldMan Performance 9 01-06-2004 11:12 AM
