Overheat after replacing timing belt and water pump - Toyota Tacoma Forum
post #1 of 17 (permalink) Old 04-15-2012, 03:22 PM Thread Starter
Hey first time poster here. 2004 Toyota Tacoma 87k in mileage V6 engine. I had the timing belt replaced on 4/9/2012 and the water pump was also changed as there was visible leakage on the unit. I have now discovered that the engine is coming close to overheating according to the temperature gauge, when I blast the heat it does come back down. It usually happens when I am driving on the highway at high speeds especially if the climate control knob is in the cold position. I have checked the coolant and it is full and so is the reservoir. I also checked the oil and that is clean and was changed very recently and it is full. There is no knocking or strange noises from the engine which I thought would be a symptom if there was an issue with the timing belt. Upon further inspection I noticed that when I turn on my A/C there is a squealing noise. When I looked under the hood the ac unit is not turning regularly but very sluggish and not in a fluid motion. Do you think this could be causing my overheating issue? Do you think this is just something in addition to the new overheating problem. As a side note prior to 4/9/2012 there were no issues with overheating and no noises, however I did not turn on the a/c unit in quite a few months. Any help from you guys would be great.
mtn984 is offline
post #2 of 17 (permalink) Old 04-15-2012, 03:57 PM
nancy's Avatar
Quoted: 4 Post(s)
Did you change the thermostat? That sounds like the culprit
nancy is offline
post #3 of 17 (permalink) Old 04-15-2012, 04:09 PM
Re: Overheat after replacing timing belt and water pump
Could have air in the system. Don't you need to turn the heater on high or push the button/lever to a certain position? Then try running the truck a few minutes without the radiator cap.
tacomaman is offline
post #4 of 17 (permalink) Old 04-15-2012, 05:37 PM
Quoted: 199 Post(s)
(1) Welcome to CT!
(2) x2 on the thermostat question. The overheating symptoms could be a sticky thermostat.
(3) The squealing when you turn on the A/C is probably a different issue, BUT ... It might be a symptom of something not right with your belts. Have you double-checked your belts since the work done last week?
post #5 of 17 (permalink) Old 04-15-2012, 05:46 PM
nancy's Avatar
Quoted: 4 Post(s)
Yup, leave the cap off and turn the heater on for a few minutes.
nancy is offline
post #6 of 17 (permalink) Old 04-15-2012, 07:26 PM
mitzu's Avatar
I was also told to have the truck at an incline so the air comes up faster
mitzu is offline
post #7 of 17 (permalink) Old 04-15-2012, 07:46 PM
NVTACO's Avatar
that helps, but as long as the radiator cap is the highest point in the cooling system, it will bleed the air out
NVTACO is offline
post #8 of 17 (permalink) Old 04-16-2012, 06:07 AM Thread Starter
I appreciate the quick responses. I had the work done with a mechanic I trust so I am hoping that the timing is ok with the belt. However I do not know if they replaced the thermostat. Tonight I will try removing the radiator cap and then starting the truck up with the heat on for 10 minutes or so to see if any air comes out. I will report back with any updates.
mtn984 is offline
post #9 of 17 (permalink) Old 04-16-2012, 05:24 PM Thread Starter
So I ran my Tacoma with the radiator cap off for about 20 minutes. A few bubbles came up to the surface and then stopped. No overheating while idling but it has only ever come close to overheating when I am on the highway after traveling for a while. Last time it happened I was on the highway for about 40 minutes and it came close to the red zone. But ever since I changed the timing belt and water pump on 4/9/2012 I swear the temperature gauge runs a little over half way and prior to that it ran about halfway exactly. I will have to take it on the highway again for a bit of a drive but I don't have time tonight.
After I was complete with the radiator burping. I noticed that when I have the heater set to defrost or if I have the A/C on any setting I get the loud squealing noise and the wheel that is attached to the A/C unit ( i believe its called the clutch) is slipping and traveling slower than the rest of the pulleys. Also the A/C blows hot air
Are these separate issues? Any other words of advice for each problem?
mtn984 is offline
post #10 of 17 (permalink) Old 04-16-2012, 07:13 PM
Quoted: 199 Post(s)
The reason you hear the squealing when you have the heat set on defrost is because the A/C compressor is engaged on this one (defrost) heat setting.
I don't think the A/C squealing issue is related to the overheating unless the compressor is causing a drag on the belt and slowing something else down.
timing belt or water pump?? freenewme 1995.5 - 2004 14 12-30-2010 01:26 PM
TOOLS for timing belt/water pump job mitzu 1995.5 - 2004 31 03-10-2009 09:15 AM
Looking for an ALL OEM Timing belt and Water Pump Kit _BEN_ Off Topic 9 06-20-2008 07:22 AM
Water pump along with Timing belt? jnguyen0819 1995.5 - 2004 7 11-11-2006 10:27 AM
Timing Belt and Water Pump 97taco4x4 1995.5 - 2004 6 08-28-2004 02:42 PM
