Check your 2rz valve clearance. - Page 3 - Toyota Tacoma Forum
post #21 of 31 (permalink) Old 02-12-2012, 01:25 PM
NVTACO's Avatar
Re: Check your 2rz valve clearance.
how does a valve get tight? Cam bearing wear? Carbon build up?
NVTACO is offline
post #22 of 31 (permalink) Old 02-12-2012, 01:31 PM
bwill808's Avatar
F.M. '''F#$KING Magic'''' kinda like how a ECM works , you just it happens
OO SR5 Tacoma 3.4 5lug slopomatic , TRD S/C, TRD headers,TRD cat - exhaust, URD 2.1 pulley, URD FTC & AFR calibrator, 2jz injectors, 255 fuel pump, IK24 spark plugs, 170 thermostat, AEM guages, homemade methonal injection, homemade rear 02 sim, sprk adv. 20+
bwill808 is offline
post #23 of 31 (permalink) Old 02-12-2012, 01:35 PM
NVTACO's Avatar
haha like posi trac
NVTACO is offline
post #24 of 31 (permalink) Old 05-22-2012, 10:06 PM
bwill808,
Do you still have shims available?
All of my exhaust valves are tight so i ended up removing the cam shafts instead of fishing the shims out.The toughest was was breaking loosen the timing chain gear bolt.
Time to invest in air tools.
cubical is offline
post #25 of 31 (permalink) Old 05-22-2012, 10:14 PM
Originally Posted by H2Oandy View Post
I am not sure. The valve adjustment is fairly straightforward but requires a special tool and the shims. I would call you local mechanic I am sure they can give you a pretty good estimate over the phone. You definitely need to have it done.
You might want to check your compression levels. That will tell you if you already have any problems with the valves.
Got a quote from Toyota dealer $650.00,just curious i would not let them touch my vehicle.
cubical is offline
post #26 of 31 (permalink) Old 05-24-2012, 12:53 AM
HiluxRSA's Avatar
Usually happens when either the valve face or valve seat (or both) wears away a bit. This causes the valve to sink deeper into the seat, effectively closing the gap (lash) between the valvestem and shim.......... when this happens, the valve does not get sufficient time to cool down on the valve seat, while cycling open and closed. It actually hangs open slightly, and thus starts to burn the valve face due to excessive heat.... almost like a cutting torch on the edge of a metal disc.......
Tight valve/s will usually show as a slight misfire, accompanied by a low manifold vacuum reading at idle........ (not sealing the cyl as it should)
Loose valve/s will emit a ticking sound.
HiluxRSA is offline
post #27 of 31 (permalink) Old 10-22-2012, 10:49 AM
Have a question going over the geometry of the shim-bucket design in my head. How increasing the clearance with a thinner shim can enable the valve to to cool better. Wouldn't increased clearance cause the valve to sit on its seat longer?
Like to know this before starting my valve adjustment effort on an 03 3RZ with 125k miles. Exhaust valves are all within spec but near the minimum.
howardc64 is offline
post #28 of 31 (permalink) Old 10-31-2012, 07:21 PM
NVTACO's Avatar
is it wear or does the valve start to bend like a umbrella or both?
NVTACO is offline
post #29 of 31 (permalink) Old 01-02-2013, 09:51 PM
My smog guy said a reason for my HC being at the max spec could be i need a valve adjustment. Does that sound right? Toyota wants $395 to do it. I called around and no one seems to do it.
tacomaman is offline
post #30 of 31 (permalink) Old 01-02-2013, 11:29 PM
StepSIde
nxrunner's Avatar
Location: Marksville, Louisiana working in Lafayette La
This info is correct.
Just had my valves done at the local stealership. $450 later... only need 3 shims at 10 bucks a piece.
2"/3" Drop~Black Headlights,Bumper&Clears~Custom Intake~MonoMax All Around~Pioneer DVD Player~Rockford T1 12 in a Custom Box~Infinity 1600watt Amp~Kicker Tweets&Mids~Custom Shift Knob~Rhino Liner~ Konig Stampede Wheels
nxrunner is offline
Check Valve on the IAC? tacomatic1 Performance 11 10-13-2011 09:10 PM
Valve Lash (Clearance) Tred 1995.5 - 2004 14 09-08-2008 12:51 PM
Need a one way check valve camacho Wanted 4 06-20-2006 07:51 PM
Need a one way check valve camacho Wanted 0 06-20-2006 03:08 PM
engine vibration and valve clearance Jademonster Performance 8 04-15-2004 01:49 PM
