Parking brake light cuts on magically. - Toyota Tacoma Forum
post #1 of 9 (permalink) Old 04-20-2008, 11:40 PM Thread Starter
Ok so basically every time I take a hard right turn, or accelerate heavily my parking brake light cuts on. The parking brake is completely released, but I can't figure out why it continues to do this.
jbmintz is offline
post #2 of 9 (permalink) Old 04-20-2008, 11:45 PM
Jiggerman's Avatar
Re: Parking brake light cuts on magically.
Check your brake fluid, could be just low enough for it not to be on all the time
I'm a simple man, I like pretty dark haired women and breakfast food.
Jiggerman is offline
post #3 of 9 (permalink) Old 04-20-2008, 11:48 PM
tylerangle1990's Avatar
x2 the little float in there is super sensitive
The taco is back and on the boost!
tylerangle1990 is offline
post #4 of 9 (permalink) Old 04-20-2008, 11:55 PM
Taco Bowl's Avatar
I have that same exact problem too. Whenever im offroading and bouncing around the light comes on cause the hand brake comes out a little bit. I think its because the parking brake is a little loose or the the springs are a little worn out. Its no biggie since all i have to do is push the brake back in.
Taco Bowl is offline
post #5 of 9 (permalink) Old 04-20-2008, 11:59 PM Thread Starter
well i'll try that about the brake fluid, but i can push againt my brake lever and it's bottomed out. It's not just getting popped out. 'll try the brake fluid
jbmintz is offline
post #6 of 9 (permalink) Old 04-21-2008, 12:13 AM
sportsman1539's Avatar
its almost always that the brake fluid is too low. it even happened to me
sportsman1539 is offline
post #7 of 9 (permalink) Old 04-21-2008, 10:14 AM
chipsndukes's Avatar
you can check that pretty easily, there's a switch somewhere along the stick that activates the light, you can duck under the dash and see it it's being tripped, otherwise with a multimeter if you're not sure.
Is probably the level, though.
chipsndukes
chipsndukes is offline
post #8 of 9 (permalink) Old 04-21-2008, 11:44 AM
Tred's Avatar
How exactly does the sensor work? I helped a friend change his rotors and pads, and bleed the brakes, and his light is on with fluid topped off. The light has never come on like this before.
Vrrm pssht!
Tred is offline
post #9 of 9 (permalink) Old 04-21-2008, 01:53 PM
If you're asking me, I'm not really sure.
The sensor on the emergency brake lever is just a simple contact like the clutch start cancel switch.
On the brake fluid reservoir there is a connector, but how the sensor works and what it measured, I don't know, maybe someone else does.
I would probably try and take the reservoir off, shake it, see if I could figure out how the sensor worked and fix it.
Chipsndukes
hand brake light won't go out TSR98TACO 1995.5 - 2004 11 09-28-2006 11:14 AM
damn 3rd brake light spyder041 Lights / Exterior Electricals 6 08-14-2006 11:29 PM
Brake light issue... P.P.F 1995.5 - 2004 4 10-26-2004 04:42 AM
Turn Signal Mod xxxxxBazzy Exterior/Body 19 09-21-2004 12:06 AM
3rd brake light screw size mazutoytaco Lights / Exterior Electricals 7 07-24-2004 04:24 AM
