headlight dim in my opinion, plug corrosion? - Toyota Tacoma Forum
post #1 of 24 (permalink) Old 12-16-2008, 11:04 PM Thread Starter
My OEM headlamps were yellowish and i thought that getting the crystal clear ones would be a world of difference (same Osram Nightbreaker lights) but its not. The plug has like yellow gunk on it iono reminds me of Lithium grease. Is the plug corroded as to not letting enough power through?
I wish i had a before and after pic of light swaps, but i dont.
ezhacker1 is offline
post #2 of 24 (permalink) Old 12-16-2008, 11:09 PM
charlie q's Avatar
Re: headlight dim in my opinion, plug corrosion?
i have the same headlights in mine
mine work really good but i put HID's i them and they work even better
you might just have old bulbs have you replaced them?
charlie q is offline
post #3 of 24 (permalink) Old 12-17-2008, 12:16 AM Thread Starter
osram night breakers are month and half old.
post #4 of 24 (permalink) Old 12-17-2008, 12:37 AM
Tillers_Rule's Avatar
Quoted: 7 Post(s)
The grease is cosmoline, just a rust-preventative.
Tillers_Rule is offline
post #5 of 24 (permalink) Old 12-17-2008, 12:52 PM Thread Starter
o, and here i thought it was causing my lights not to be as bright as i would think aftermarket headlamp/light to be.
i should still check voltage tho.
post #6 of 24 (permalink) Old 12-17-2008, 03:16 PM
BOOSTED
trdspectacoma's Avatar
what I noticed with the diamond cut ones like I also have on my truck is that they spread the light in all different directions because of the cut. I put HIDs in it and it got worst than the halogens. If you want it a little more bright put in a good wiring harness that draws the power off of the battery. If you want it really bright retrofit a projector with real HIDs
trdspectacoma is offline
post #7 of 24 (permalink) Old 12-17-2008, 11:49 PM
nancy's Avatar
Quoted: 4 Post(s)
your problem is that you're using a halogen bulb. output is gonna suck unless you upgrade to HID.
nancy is offline
post #8 of 24 (permalink) Old 12-18-2008, 01:29 AM Thread Starter
well even comparing with oem headlamps i expected clears to be better. but yeah i guess the aftermarket is for looks.
would taking the clear cover and putting it onto the oem reflector work out? or is there a reason for the oem cover the way it is.
post #9 of 24 (permalink) Old 12-18-2008, 01:33 AM
Quoted: 76 Post(s)
try cleaning out the gunk in your connectors and using some dialectic grease..
you can fint it at most auto parts stores, its for electrical connections..
post #10 of 24 (permalink) Old 12-18-2008, 01:48 AM
I like my black crystal lights. The light bouncing off the diamond cut chrome parts makes for a different light pattern though so you get bright spots.
tacomaman1999 is offline
Will Bush Cancel The 2008 Election? OXI Off Topic 48 08-06-2007 11:38 AM
05-06 Passenger side headlight thumper4863 Parts and Accessories 1 11-05-2006 08:54 PM
I NEED a passenger headlight 98-00 mustangsvo85 Wanted 3 02-07-2006 10:18 PM
Headlight removal... need help bigd9247 Lights / Exterior Electricals 5 12-03-2003 12:40 AM
Do you have spark plug questions? newt Performance 12 12-01-2002 10:43 PM
