Hand Throttle - Toyota Tacoma Forum
post #1 of 21 (permalink) Old 07-04-2008, 03:02 AM Thread Starter
Hand Throttle
So I've done some research and looked around and I'm wondering if anyone here has installed a hand throttle on their Tacoma. I have some friends that all drive Jeep's and swear by it, so I figured I'd give it a try. It's very inexpensive, just a bike shifter and some cable, but I'm wondering if that has been done on a Tacoma before. Anyone know? Thanks in advance!
gsxrmike is offline
post #2 of 21 (permalink) Old 07-04-2008, 02:22 PM
battlescars's Avatar
Quoted: 12 Post(s)
Re: Hand Throttle
That doesn't sound like a hard task. I personally have never done it but re-routing your throttle cable to a bike throttle and say, mounting it somewhere easy to access wouldn't be too hard. I would think when you throw a clutch in there things may get a little complicated but still not that bad. Why don't you give it a shot and show us the end result? If you say your buddies have it on their jeeps, I don't see if being much different.
battlescars is offline
post #3 of 21 (permalink) Old 07-04-2008, 07:31 PM Thread Starter
Re: Hand Throttle
Will do. I'm having difficulty finding the type of bike shifter I need, but if I can come across it this weekend I plan on installing it ASAP. I'll see what I can find, put it in, a do a Tech write-up for it too. Just wanted to see if anyone had done it before.
gsxrmike is offline
post #4 of 21 (permalink) Old 07-05-2008, 12:50 AM
Quoted: 12 Post(s)
Re: Hand Throttle
It really doesn't seem like a hard task at hand. It would be better to get a good hand throttle though which has a good spring in it so it can spring back (especially for a clutch). To me this seems like a waste of time, and unless your disabled, why bother you know.
post #5 of 21 (permalink) Old 07-05-2008, 12:56 AM Thread Starter
Re: Hand Throttle
It's not just meant for someone that is disabled, it's meant to be used when crawling a steep hill in 4Lo and it's a uneven terrain. With that much low end torque you're bound to be bouncing your foot on and off the gas, and you have to keep switching between the brake and gas. With this you can set the rev and just focus on the brake and clutch, it's like adding a third leg.
gsxrmike is offline
post #6 of 21 (permalink) Old 07-07-2008, 09:50 AM
Re: Hand Throttle
I've seen a few guys with older pickups have the hand throttle attached to the shifter. It comes in handy on steep hills like you said. You can buy kits for a Jeep and adapt them to a Toyota. Not hard at all. Or you can get a regular bike brake handle, attach a piece of cable to it, and then hook it up to the normal throttle cable so that both the pedal AND handle work independently.
I'm thinking about one since I have a 85 pickup with a 22R. Carb'd engines and steep hills do not get along.
Rodge is offline
post #7 of 21 (permalink) Old 07-08-2008, 01:54 PM
Quoted: 12 Post(s)
Re: Hand Throttle
You live in San Diego though, where are you going that you need 4x? Most trails and stuff around here I can do in 2wd!
post #8 of 21 (permalink) Old 07-08-2008, 01:55 PM Thread Starter
Re: Hand Throttle
Yeah, I ended up going to a local bike shop and picking up the shifter lever that I needed. Apparently the "static shifter" is what it's called, and it hasn't been used in over a decade, so you have to find a bike shop that carries older parts. I picked it up for 50 cents, and got 9 feet of cable and 8 feet of sheating for it, plus all the odds and ends to connect it all together. I'm going to hook it up tonight and see how it does. This way it's independent from the pedal, but will allow me to have a higher rev when stopped up and big hill, running a winch, etc.
The guy I went to had about 20 of these levers in stock, so maybe I can start making these for us.....
Hmm.......
gsxrmike is offline
post #9 of 21 (permalink) Old 07-08-2008, 03:47 PM
Re: Hand Throttle
theres acouple of guys on ttora using a hand throttle system i saw the picture of it u might be able to find it on there
AZNPG is offline
post #10 of 21 (permalink) Old 07-08-2008, 05:02 PM Thread Starter
Re: Hand Throttle
Follow me and you will see why you need 4wd.
gsxrmike is offline
