New to the forums so bare with me.
Got an 01 regular cab with completely shot stock suspension. I'm hauling around 5-750 lbs a day and doing some spirited driving now and then. Friend who works at Lexus said if I just replaced all shocks and leafs etc it would run me about 1300$ even with his employee pricing.
Did about an hour or 2 of research and it seems like my best bet is 10" qa1s up front with an upgraded sway bar. Then replacing rear shocks and doing the 4x4 leaf swap and adding a sway bar?
My main goal is improved handling while still being able to haul around a decent amount. I don't want to lower the car more than 2 inches up front and maybe 2-3 in the rear.
Please give me your two cents if you've done any of these mods, or think I'm going in the wrong direction. I'm by no means a suspension expert so all advice and information welcome.
Thank you!!!
Also I can't find the part number for the qa1's for my truck... Help??
Thank you!!!
