2002 Toyota Tacoma v6 2wd Rear Locker 4.30 gears AUTO.
So few weeks ago I replaced my Center Carrier Bearing before I went to pismo. Bought it from NAPA for 120 I think. Came back from pismo everything was fine (No Clunk). Then just this week I have a bad Clunk when Backing up in Reverse Then Going into Drive or visa versa. A Loud Bang Sound happens when I go from D to R or R to D. So I went to grease everything on my drive line.
I Greased Up this thing till grease came out.
Grease Came Out From Here. The brown mark is where it was before. It MOVED. DID I PUT TO MUCH?
Then I looked at the Cener Carrier Bearing. It came off the rubber Housing.
Side Picture.
Looks like its been hitting. Center Bearing was lose before Greasing.
I just started to look at my Tranny Mount.
Did i put to much grease in that rear zerk? Because its causing the Bearing to come out.. Prior To greasing the Center Carrier bearing was lose when pushing up on the drive shaft. Now the drive shaft is Tight, Leaf springs are Positive Arch (before was Neg). I assume i need to get a new CB and Tran mount but i want to know if i put to much grease in or is this how it should be. __________________
Side Picture.
