I just recently replaced my carrier bearing with an aftermarket one and I greased up the driveline shaft but after about 2 days of driving it starts to make a squeal noise. Doesn't sound like the bearing but more like rubbing of driveline on bushing. The aftermarket bearing was quite different from OEM in design. It has a sealed bearing and rubber bushings at each end to keep dirt out. Does anyone think that the rubber bushings is whats making the hoise?:shrug:
Also forgot to mention that it only makes the noise after I've put a few miles on it. Never makes the noise right away after its been sitting for awhile. Cooled down.
